Mettler »
https://forums.nicoclub.com/mettler-u36299.html
Thu Oct 23, 2008 10:08 am
Yeah, ****loads! I've been investigating down this path for a while, many of the superstock race cars here running the VH41 crank and sleeved down to 4L are still producing 500HP+
Factory valvelift is only something like 9.2 or 9.3mm, bringing that right out to 12.7mm (1/2") and changing the intake valve closure point for an increase in dynamic compression ratio should raise the curve across the whole rev range.
A VH45DE with 450HP at the flywheel with intake freed up a bit, extractors, valvesprings & cams doesn't seem out of the question. Do a search for old threads regarding this.
