Solow240sx »
https://forums.nicoclub.com/solow240sx-u103308.html
Wed Nov 12, 2008 5:39 am
Ok guys so as some of you know i am fully building my sr20, but this is the first one i have ever done, I have the head, and the block complete and put them together last weekend and torqued the headstuds down, after that i installed my HLA'S, shims which i measured and they were all 3mm then i installed the rocker arms and my new Tomie 270's no this is where i am at now, and im pretty sure i need to check the clearances between the rocker arm pad, and the cam lobe, but i just read on another site that the HLA'S don't need to be adjusted for and you only have to check clearances with solid lifters, im pretty sure this is BS but just wanted to make sure, also does anyone know what the clearance should be between the pad and the cam, i have not be able to find it anywhere...
