valve seals
nissan~240sx
Car: 1993 Nissan 240sx SR Blacktop...Finally Boosting
there's blue smoke coming out of my tail pipe and of my breather from the catch can. i also dont have the proper oil restrictor on my car right now. will this lead to a valve seal burst or burnt piston rings or both?
when i do the compression check, what numbers are normal?
H8tred
Sounds like your rings and or ring lands are toast now. 180 across the board is perfect.
nissan~240sx
so a blown valve seal wouldnt cause the smoke to happen? its definitely a blown piston ring? the car runs but theres just a lot of smoke. sometimes its blue, sometimes just white. the tune is off by alot, car runs very rich. if its only blue sometimes, what does that mean? i kno the car is burning a lot of gas..
H8tred
My seals were bad, and I only got smoke at tip in. The only way you would be blowing smoke out the pcv system would be 1. The exhaust side seals are pretty much non existent (Which would be no to very light smoke unless you have a 1/2 inch exhaust), or 2. combustion gases are making their way past the rings, into the crankcase causing positive pressure in the pcv tract and finding the easiest way out, being your valve cover.
The ring lands of all 4 of my pistons in turbo duce were gone, and I was blowing smoke and oil out of the valve cover. My numbers were like 40, 50, 170, 70... The 92 auto tragic had a perfect 180 across the board, and I had just replaced all valve seals with blue viton seals. Then I spun a rod bearing. Haven't checked the compression in my Canadian model, but I suspect it isn't up to snuff as I can run 89 in it with no ping. The 92 would go ape **** if I put anything other than 93 in it.
**EditAssuming you have a turbo KA, I would venture to say that your ring lands are shot. Give me some info on your set up and boost levels.
nissan~240sx
H8tred wrote:My seals were bad, and I only got smoke at tip in. The only way you would be blowing smoke out the pcv system would be 1. The exhaust side seals are pretty much non existent (Which would be no to very light smoke unless you have a 1/2 inch exhaust), or 2. combustion gases are making their way past the rings, into the crankcase causing positive pressure in the pcv tract and finding the easiest way out, being your valve cover.
no no no...i got a 96 s13 sr20det blacktop...does this make a difference?
H8tred
Not really. Do a compression test and get back with the numbers.
