valve rocker and arm assembly
madblkscientist
Car: 1997 mitsubishi eclipse gst eclipse (RIP 2001-2005) 1989 240sx (2008) 1995 mitsubishi eclipse gsx(20
Hi how are u doing and thanx in advance
I have very recently aquiered a 89 240sx with a ka24e single over head cam it was running and i was planning to turbocharge it until it stop working
it turns over it is getting gas then i did a compression test # 1 2 piston cambers had no pressure 3 had very little and 4 had like 180 so i taught dam gotta rebuild head until i relised that the valve roker assembly was lifting up as i rotated the engine.a couple of bolts the hold down the shaft was lifting up and down i tried tighening them but it was threaded out so my question is,
can i just remove the assembly and drill/tap a bigger bolt into it
what size is the original bolt
and what size higher can i go
when i took the plugs out and rotated the engine i think i felt i build up of pressure so maybe the valves are still good and i need only bolt the assembly down 100 percent
seang
Car: Ford Fiesta ST
If the threads are stripped you either have to drill and tap to a larger size, (if a larger hole wouldn't compromise the strength of the rocker shaft), or Heli-Coil them.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I personally would see what a machine shop can do in this situation.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
Yes, you can drill out for a bigger hole, but you'll end up stripping the threads again. I don't know why but it seems they don't like torque after a lot of miles. All ten of the holes on my head have heli-coils in them. It doesn't take long to do but you do need a steady hand. IIRC the bolts are M10X1.25 but don't quote me on that. You can go to the hardware store with one of the bols and get it sized and also get a heli-coil set for the bolt size you have.
Just use the recomended drill size to drill the hole bigger,Use the tap included with the kit,insert heli-coil in the hole,and re-assemble rocker assembly to the factory torque specs.
Heli-coils acually add strength to the threads. Most manufacturers acually use thread inserts on aluminum parts that see high torque items like block to head mounting holes. So, you can only gain when you use heli-coils.
madblkscientist
where can i order the heli coils from im in miami,florida
seang
Car: Ford Fiesta ST
Heli-coils are available at lots of places over the counter
madblkscientist
like
seang
Car: Ford Fiesta ST
I think Napa has them
madblkscientist
seang wrote:I think Napa has them
ok gonna check 2mmorow
madblkscientist
ok the exh valves on cylinder 1 n 2 r leaking it wont hold compression and when i blow compressed air tru the spark plug hole it goes str8 into the exh
seang
Car: Ford Fiesta ST
It might have burned exhaust valves from someone beating the crap out of it.
madblkscientist
im in
seang wrote:It might have burned exhaust valves from someone beating the crap out of it.
im in the process of pulling the engine out to rebuild it now i gotta find a good rebuild kit that has everything minus pistons+rods
and 1 with pistons and rodsams has a kit but its pricey and those pistons look like low comp pistons
i wanna bump the compression up and run low boost for shi*s n giggles then imma take it off bcuz imma ship it 2 the islands
so any info will help on setups n such
wa-chiss
2005 Toyota Sequoia
it might be hard to find them, but NISMO has a set of high compression pistons for the SOHC. Something like 11:1 CR.
