valve question, please help
opensource
i will know tomorrow if we need them or not, but i need to know the valve specs (sizes, type, etc) that are used in the rb25det. is there US a equivalent and if not where can i get a cheap set in the US. thanks.
FAST-DATSUN
I do not think there are a US equivalent of the RB valve, but most High performance valve companies can make them..Why do you need them?????
Mack @ Mckinney Motorsports
93semax
This should help. AFAIK there is no us equivalent. You can probably call up ferrea and ask them to make a custom set..
opensource
damn the link didn't work, looks like it was taken down. does anyone remember what it said?
93semax
opensource wrote:damn the link didn't work, looks like it was taken down. does anyone remember what it said?
copy and paste this http://www.geocities.com/vg30etmax/rbspec.jpg
I took a pic of my r33 engine manual.
opensource
you sir are the man!
opensource
FAST-DATSUN:
Right timing pulley broke on my buddies RB. Happend at low rpm, but still fearing the valves are bent.
opensource
****idy **** ****, zero compression. it needs a head or a set of valves.
FAST-DATSUN
First find out why the pulley broke, it might happen again if something is not right. Do a leak down test to see if the valves are bent. If they are you might/probley broke some valve guides also. Make sure the head is done by a very good shop so all problems are fixed......
opensource
we used to short of a bolt for the pully. when we re-assembled it the first time, the wrong bolt got used. it was to short. that and i think the timing belt was to tight. i installed the correct bolt this time, grade 8 too. with all the spark plugs installed and you try to start it it just spins so free, there is no compression at all in the motor.
