Valve problems
Ylw55
Car: 1993 hard body 2.4 5 speed
Hi new guy here with truck issues. 1993 hb 2.4. Recently bought this truck, it has been sitting since 2006 with a bad trans. Replaced trans and it runs great, but sometimes when it is parked over night or several hours, when I try to start it spins over like it has no compression. Also has a ticking sound as it spins. But after it spins for a while it starts. Sounds to me like the lifters are losing their prime or they are getting stuck. I have serviced the engine and added stp. Anyone heard of anything like this before?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The hydraulic lifters can become clogged with sludge and cause quite a rattle upon start up. They can also loose their prime and fill with air causing quite a rattle until all the air is purged. Have you pulled the valve cover off the head to check the internals visually yet?
Ylw55
No I have not. They do not rattle. It seems as though after the truck sits for a while they are either holding the valves open or not opening them until they prime back up. The truck spins over with no compression.
Ylw55
It sounds like the timing chain has broke when I start to try and start it. Anyone have any clue?
