DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Tue Nov 01, 2005 7:43 am
hydraulic lifters are hydraulicly adjusted lifters, and he was just tryin to sound as intelligent as possible. He may know his E has hydraulics but DE don't they're quite solid.
i'm not too sure he's not a mechanic himself so he doesnt want to hear another mechanic trash-talked. About a KA, I always trust people who have actual experience with KAs over people who have a vague knowledge over everything. In those instances you tend to get ridiculous diagnoses such as the hyrdraulic lifters your car doesnt have are causing a problem, so on and so forth.
this gurgling noise isn't nearly a good enough description, maybe an actual sound clip would help, but from past experience, and from one KA i just got running a few nights ago, its quite easy to have a timing chain tensioner problem.
i'm still guessing the gurgling is the chain hitting the valve cover. However, he says its slop between the cam lobes and the buckets and shims. I can imagine that would be a far more nasty noise, and i have yet to encounter this problem
just get an oil pressure gauge, hook it up to the pressure switch and test, this coulda been said like ten posts up and it woulda easily solved the situation, but instead some people just like to complicate things, quite wrongly too
