Valve Noise When Cold
A34D4ME
Car: 89 coup
1989 240SX:
For some time I've suspected that my car needs valve guide seals - Burning oil when cold.
Now, when it's cold, something is clattering like crazy. It sounds like a stuck valve. This goes away when it warms up but I noticed, when I removed the oil filler cap, that copeous amounts of air pulsate from my valve cover.
Could this clatter be a sticky lifter? Is it normal to have air pulsating from the valve cover?
My car seems to run great with this one exception.
arg0nut
Car: 1990 240 SX
You have a couple of possabilities.1) you have a leaking valve guide/seal2) you have a PVC Valve clogged.
For #1 you need to pull each spark plug to see which one looks fouled...it will be oily or black. This will tellyou which valve guide/seal is leaking. If you're going to replacve one...replace them all.
For #2 which is where the pulsating air comes from....just replace the PVC Valve.
A34D4ME
Car: 89 coup
Thanks for the help. But I think it might be better to replace the PCV valve than the PVC valve. LOL.
Thank's & Merry Xmass.
arg0nut
Car: 1990 240 SX
You're right, and I have fat fingers.
