deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Dec 26, 2005 11:37 am
It is normal to have some blowby, that is what you are feeling through your oil cap.
Check you valve lash, any that are showing more that .013" are probably where your cold noise is coming from. Once it warms the valves are at temperature, the stems elongate closing some of the lash. This is why the lash is .011-.013" (wide compared to most valvetrains).
Edit: didnt read your post very clearly (was thinking dohc), with your sohc you are more than likely experiencing a lifter issue, that is if you are sure it is in the valvetrain and not the timing chain dragging.
Modified by deviousKA at 10:15 PM 12/26/2005
