svwilbur »
https://forums.nicoclub.com/svwilbur-u128801.html
Fri May 22, 2009 1:05 pm
We have a 1990 240sx S13 SOHC with stock KA24E engine. Manual transmision, coupe.
It has 144K and was "rebuilt" according to previous owned 50k ago.The engine runs great and pulls hard and has smooth excelleration.
But when it is started I get about 1 to 2 seconds of what sounds like valve noise tapping/rapping toward the front of the engine. Could be timing chain maybe not sure what it is.
But it makes a rapping sound for a second or two then goes away completely and runs quiet and smooth from then on.
It does it from when the engine ignites and while cranking and for a bit after the key is released so I do not think it is the starter.
I have read that sometimes a part or the timing belt tensioner can get loose/broken off and rattle around but this is noise I have is real consistent. Each start I think. It may not do it on some warm starts. But most all starts has the noise. And never after it has been running for 2 or 3 seconds.
Kind of like it is not getting oil to some of the front valves right away.
Should I be worried?Any recommendations on additives or resolution?It has a new filter and clean oil but still makes the noise.
