slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Thu Jul 07, 2005 8:31 pm
Well for the DE heads, there is no 'adjustment' in the typical sense. There are round shims, which ride under the cam lobes, and on top of the valve buckets. These shims don't wear too much, which is probably why they told you an adjustment isn't necessary(unless you recently rebuilt the head). Not a bad idea to check them anyways.
Intake is 0.012"-0.015", exhaust is 0.013"-0.016". Remember a little loose is always better than a little tight.
