Valve height?
tommey
Car: S13 ca18det
I was curious, do anyone here know what the stock valve "height" is on the CA?
I am thinking of how much the valve sticks out from the guide inside the head.
When machining the valve seats and grinding the valves, you move/raise the valve, whats the stock measurement?
Not sure if i am explaining good enough here, do you guys need a pro paint drawing?
Rambo24o
Car: S13 240sx
Rambo24o
Car: S13 240sx
Rambo24o wrote:[img]<a%20class="vglnk"%20title="Link%20added%20by%20VigLink"%20rel="nofollow"%20href="http://i1138.photobucket.com/albums/n52 ... AG0575.jpg[/img">http://i1138.photobucket.com/albums/n52 ... AG0575.jpg[/img</a>]
[IMG]http://i1138.photobucket.com/albums/n52 ... AG0575.jpg[/img]
Hope this helps
tommey
Car: S13 ca18det
Sorry, it didnt give me the measurement i needed.
Here`s a drawing:
float_6969
If you're still using hydraulic lifters, they should be able to easily compensate for the small change in valve height from grinding the valve seats.
Regardless, I've looked through the FSM, and you're right. I don't see that spec listed in there anywhere. My head has been ground so I can't measure it for you and know that it's a factory spec. Maybe Boost Boy has a head laying around he can measure for you?
tommey
Car: S13 ca18det
Yes they should compensate, but this head has been machined before, and not by me.
Now i have to machine it again and the valve seats are getting really low.
Just wanted to make sure.
I have some stock untouched heads i can measure myself, then i will update this thread :)
themadscientist
Install new valve seats.
tommey
Car: S13 ca18det
Of course i can do that, but i wont do that unless its necessary.
datso
Car: datsun 1000
have you though of using the rb25 valves? Im thinking of using some custom stainless valves for the exhaust side 1.5mm bigger and one 36mm on the inlet to work with staggered camshaft grind form Colt cams.
tommey
Car: S13 ca18det
I have but i dont know the size of them, i have some lying around somewhere.
datso
Car: datsun 1000
I still dont have enough posts to contact you tommey wont be long I hope.
The RB25 valves are longer also which perhaps are needed for 12mm and over lift.
I cant find the place now but they have the best prices Ive seen for aftermarket valves, will keep looking.
tommey
Car: S13 ca18det
If they are longer then that is perfect for me!
I have been looking into getting some longer valves to go with my Tomei lifters.
I want to run them without shims and adjust the valves instead.
Going to dig trough some old rb parts today!
datso
Car: datsun 1000
definitely longer valves on the RB but still cant find the link with the Stainless steel aftermarket ones. They where around 13-16usd each valve! quite reasonable.
datso
Car: datsun 1000
Tommey tried PMing you back but says "Some users couldn’t be added as they have disabled private message receipt."
By the way still cant find the SS valves supplier online that you can check all the data will keep searching.
tommey
Car: S13 ca18det
Should be OK now, i have recieved PM`s before.,
datso
Car: datsun 1000
thankU finally working
