DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Jun 17, 2004 3:23 am
What do you mean by "chain is loose?" You mean it's loose because there's no guide there now, or it's loose because it has slack in it? How much slack a timing chain has when the cover is off has no relationship to how much slack it has when the engine is running. If slack is the concern, make sure you replace the chain tensioners, guides and the oil pump chain/guides.
