ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Fri Dec 22, 2017 12:02 pm
I know this is an old thread but I have a question, I think the seals in my 93 Hardbody with the KA24E are bad, it smokes at startup and after sitting in traffic when I rev the engine, Does the cam gear and chain need to be removed before removing the rocker assembly? Someone told me that the rockers keep tension on the cam so it would be best to remove the gear/chain? Question on that is, if you remove the cam gear and chain, and people have said to have the piston in the cylinder you are working on at TDC, how would you set it at TDC if the cam gear is off?
I don't have a problem doing the work myself but I don't want to screw up the timing or anything else.
So basically, remove the valve cover and the plugs, put the trans in gear to prevent the piston from moving when you pressurize the cylinder, remove the rocker assembly, pressurize the cylinder your working on, compress the spring and remove the retainers, remove the spring, remove the old seal, install new seal, and reassemble, move to next one, correct?
Engine is original inside as far as I know and has 268K miles on it, it runs strong, runs at normal temp and I average 19-20 MPG, it's in a 2wd with the 5 speed on stock height tires. I replaced the oil pump and all the timing parts and I have a mechanical Autometer oil pressure gauge so I know my oil pressure is good.
Thanks
