So anyway which is better for an oilpan reseal- the rubber one peace gasket or the u rings and silicone?
Also has anyone done resealed valve covers- that giant intake kinda scares me
That's some golden advice.t.mcginley.jr wrote:When you go to put the intake plenum back on, the easiest way is to buy some studs from home depot or lowes that match the actual bolts. Then you can just sit the paper gasket where it needs to be and lower the plenum down onto the studs, that way its perfectly lined up. Then just take out one stud at a time (they don't have to be in tight at all) and replace them with the actual bolts. Then just torque everything down. I'm not sure of the actual size of the stock bolts for the plenum but you can just take one with you to match up. If you have a helper to put the plenum on you don't need to use studs you can just put two bolts in while each of you lowers it from one side.
