elitefew22197 »
https://forums.nicoclub.com/elitefew22197-u191258.html
Wed Apr 18, 2012 8:37 pm
I had a similar situation not too long ago. This is what my tuner told me to do.
Run the hose from the block to one side of the valve cover T, and the other side of the valve cover T to one nipple on the catch can, then a hose on the other nipple on the catch can, to a spot on the intake pipe(source before charge). This will properly complete a vacuum circuit.
Also, some oil catch cans out there have 2 nipples on them. Others have 3, these incorporate a breather filter. So, if you do end up running this setup you may want to block that off somehow. That way you don't get rid of a vacuum leak while creating another. Personally, I welded mine closed.
