valve cover studs
J240sx
Car: 89 240sx
Anyone know where I can order some valve cover studs from? One of mine broke off and needs to be replaced. I know enjuku has them but they take forever to ship. Frsport has them but I believe they sell all of the parts separately. Also some of them are stuck on, when i try to take them off they just keep spinning. Any advice on getting them off?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Nissan. The studs are identical to the FWD. The only different stud is the center stud. You'd have to order that from someone that can order off the Japanese catalog (ie WestCo).
J240sx
Car: 89 240sx
Thanks, is there any particular year engine I should be getting these off of? And from what vehicle?
Hijacker
'94 F-150
Sentra SE-R. I usually order from a '92 since that's the model year for my 240, but any year of Sentra that sported the 2.0 in the SE-R trim.
J240sx
Car: 89 240sx
Ahh thank you, your a plethora of information. Any suggestions on how to get the stuck screws off? Some of them just keep spinning, maybe I should just try and pop those out with a screw driver or pliers.
vin diesel
Car: 99 328i
i went to my hardware store got a stainless steel bolt and 3 nuts for it. cut the bolt to the length of the the stud and used the nuts as the spacer. it worked great. i also got a acorn nut for it. works fine.
Hijacker
'94 F-150
Usually I unscrew stuck ones till they come out of the head. Then I use two wrenches to pop the nut loose from the stud.
J240sx
Car: 89 240sx
Thanks for all of the help. I still haven't drove my car yet since the swap so im looking forward to it.
