Platinum04 »
https://forums.nicoclub.com/platinum04-u263651.html
Fri Apr 15, 2016 8:36 am
I also am on the same quest, my suggestion is to look on youtube for video forums showing similar repair procedures on say a Nissan quest or a vehicle from the Nissan family with a 3.5L engine. I also have the Haynes manual for my vehicle which shows step by step procedures. I can say that make sure you have all the seals/gaskets I:E Upper plenum, sparkplugs and of course the valve cover gaskets themselves. My biggest concern is labeling the vacuum lines and torques specs. I hope this is helpful. Good luck cause I know I'm going to need it don't want to screw my Path up, just doing some preventive maintenance and reach at least 300K miles.
