Yea dude, pain in the a**. Check your car for oil-leaks in the spark plug tube, don't take them out, run a timing-test and then have your mechanic dig into it and repair that crap before it becomes into this nightmare.pharaohEG08 wrote:Wow man you just ran into a whole bunch of issues all of a sudden. Sorry to hear that, hopefully you can get it fixed quickly and as cheap as possible.
Unfortunately I lost this pics when I closed my domain...but the line is on the left side (passenger side) of the engine and runs from the back into the side of the intake manifold...just disconnect the back portion (host clamp) and have someone in the car to rev the motor while the hose is sucking up the Seafoam (they should maintain like 4k rpm) and then once you're done, have them turn the car off. Let it sit for 30 minutes or more and then start it up and let it idle, rev it, etc. You'll probably have a ton of smoke similar to my video.hsingh2088 wrote:Thanks for the quick response. It seems that the how to for the sea foam is missing a few pictures. Is there another how to on this thread? I haven't found one yet.
Also, the shop did not turn my engine over, that was my bad.
The mechanic was pretty up front about it and I am almost certain there is oil right on top of my cat.
You need to be very careful revving these M35's high when the car is cold. wait at least 5 full minutes before you take the engine above 5k rpms. We have really weak valve covers and they do start to leak if you rev high when things are cold. I have had it happen 3 times, all at the beginning of winter as the temperatures are getting lower. I had it happen 3 years in a row till I finally stopped driving so hard. It was about the time my warranty ran out. lol. Never had a problem with valve covers leaking since I stopped driving hard in the first 5 minutes though.svard75 wrote:A valve cover doesn't just suddenly start to leak right?
Sound advice.EniGmA1987 wrote:You need to be very careful revving these M35's high when the car is cold. wait at least 5 full minutes before you take the engine above 5k rpms. We have really weak valve covers and they do start to leak if you rev high when things are cold. I have had it happen 3 times, all at the beginning of winter as the temperatures are getting lower. I had it happen 3 years in a row till I finally stopped driving so hard. It was about the time my warranty ran out. lol. Never had a problem with valve covers leaking since I stopped driving hard in the first 5 minutes though.svard75 wrote:A valve cover doesn't just suddenly start to leak right?
That is probably an accurate statement, but what I've been wondering is, why hasn't my CEL gone off prior to me changing the plugs? If it had been leaking for a long time, shouldn't any burned fuel/oil have already leaked into the cats; thus, setting of the code P0430 and P0420? (btw, only P0430 was set off, there was no P0420)svard75 wrote:You missed my point. Clearly you had an issue of leaking valve cover for some time. The oil contaminated the plug long before you changed the plugs out so my thoughts are that this was over a longer period of time even before you began messing around. What did the original plugs look like when you removed them? A valve cover doesn't just suddenly start to leak right?
Thanks for the advice dude. The coil paks were fine, the only thing that went bad was one of the plugs I replaced. The other 5 plugs were fine when the mechanic tore everything apart. These engines are ridiculously hard to work on...CPJ LB wrote:not sure how long you had the leaky valve covers and the oil in the spark plug tubes, but you may want to also check the coil paks related to the oiled spark plug tube(s). that will also contribute to misfire and poor mpg's.
as far as cats...you can always pick up a set from the G35 forum classifieds....you can save a lot of money going that route for replacement cats....typically $100-$200 a pair... I've gone that route when I ran hi flow cats and needed a set when getting smogged
Orange burned plugs are a good indicator you're running too lean, brownish gummed up means its an oil leak. Catalyst codes can be pending for a while before they trigger the final code or SES light. I think it was simply coincidental.hsingh2088 wrote:That is probably an accurate statement, but what I've been wondering is, why hasn't my CEL gone off prior to me changing the plugs? If it had been leaking for a long time, shouldn't any burned fuel/oil have already leaked into the cats; thus, setting of the code P0430 and P0420? (btw, only P0430 was set off, there was no P0420)svard75 wrote:You missed my point. Clearly you had an issue of leaking valve cover for some time. The oil contaminated the plug long before you changed the plugs out so my thoughts are that this was over a longer period of time even before you began messing around. What did the original plugs look like when you removed them? A valve cover doesn't just suddenly start to leak right?
The plugs looked pretty bad, there was corrosion on the anode and tip (I live in Houston, very humid weather and salty air because of the Gulf), and traces of burned oil around the threads, but cyls 5 & 6 had the most wet oil on them when I pulled them out, probably half a tea-spoon each.
In any case, hopefully all of this will blow over soon, if not, looks like I'm going to have to fork over a few hundred for replacement cats, might as well change both.
