Valve Cover Removal
Silvia D Rifter
Just for reference, I have a 91' 240 hatch.
I've been reading up on the timing chain rattle that nearly every KA24 owner has experienced. Through the FAQ and various threads on here, I figured out that the little metal part that sits between the two cams on my KA is to blame, and (as recommended by Nissan) should simply be removed. The way I read, there's only two bolts holding the thing on.
My question is this: How involved is taking the thing off? I'm looking at my KA, and I see a valve cover with four bolts holding it to the block. Is it as simple as removing that cover, taking the metal part off, and replacing the cover? I have a Chiltons guide, and all I can find relating to the timing chain are procedures involving TDC and the distributor, which I hope isn't necessary in my case, since I'm not actually messing with timing here, just removal of a part.
Can anyone help me out? That rattle at idle is driving me up a f***ing wall, and makes my 240 sound like a POS.
Hijacker
Car: '92 240sx Convertible
'94 F-150
all you need to do is pull the cover, pull the part, reinstall cover. That part you're talking about though, is chain guide. not sure how it will effect the engine or not.
MR2NER
Car: 1991 240SX
I have the same problem and always wondered how to take care of it.
twofourzeroSX
Car: 91 sileighty
how loud is this clicking/ rattle, because i have a rattle too and i always thought it was my exaust heat shield as some people had problems with, but its not. this could be it.
MR2NER
Car: 1991 240SX
Mine is a clicking. It's bad when I idle but I can only hear it slightly while I'm driving.
MR2NER
Car: 1991 240SX
Is it fine to just tighten the valve cover by hand or should it be torqued down?
Silvia D Rifter
MR2NER wrote:Is it fine to just tighten the valve cover by hand or should it be torqued down?
Yeah, I'm wondering this, too. Is there a sequence to the bolts, and should I use my torque wrench when replacing the cover?
I don't think it's my exhaust heat shield, either. I've put my ear right next to the front of the valve cover, and it seems to be coming from right there.
twofourzeroSX
Car: 91 sileighty
are there any answers??
Silvia D Rifter
*bump*
BadMojo
Car: 2007 Mazdaspeed 3
Silvia D Rifter wrote:Yeah, I'm wondering this, too. Is there a sequence to the bolts, and should I use my torque wrench when replacing the cover?
Yes, there's a sequence and yes you need to follow the torque specs.
Unfortunately, I don't have my FSM right now. Keep in mind that the head is aluminum and you DO NOT want to overtorque anything.
Silvia D Rifter
Well, I popped off the valve cover tonight, and found something interesting. The guide in question was supposed to attached to the engine between the two cam gears, by two bolts. Well, it appears that the guide was either broken off, or broke off on it's own, leaving the two bolts and the base piece of the guide still in the engine! I'll have a pic soon, as soon as I can get a hold of my camera.
I'm thinking the guide was broken off intentionally, cause looking down the chain, I can't really see where a piece like that would go with out seriously f***ing something up.
*sigh* I had come up with two possible solutions to my rattle problem. One was using regular oil instead of synthetic, which I tried with no success. This was my second possability. Since there is no guide to take off, it means I've probably got a more serious problem on my hands, something relating to a timing chain replacement.
Well, I guess I'll go back and put the cover on. I've got the DLable version of the FSM here, so I should be able to get the cover on with out incident. Wish me luck!
xatracing
Car: 240 bandit
they tend to break alot - did you find the other piece?
