This question shouldn't be in the KA-T section, but I'll answer it anyway
The letters are just more aluminum; the whole thing is made out of aluminum. However, as it is aluminum, it's very soft, so be careful when sanding as you can distort/chew up the surface of the letters fairly easily. It all depends what you're sanding it with, but I'd start off with pretty fine material and work your way up.
