Valve cover Question
slavetothemuzic
Car: 1991 240SX Fastback
I was just looking at my valve covers.
I'm sending a set to get powdercoated (I have a spare set I picked up).
Problem is, it seems like the tubes on top that the hoses connect to are pretty well static, and one set has them, the other set doesn't.
See photo for the tubes I'm talking about.
Does anyone know if you can remove those without damaging them? They seem really tight in there, and I'm afraid of bending them up if I try to pull them.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I am pretty sure they are press fit in there so you need to press them out. I doubt you could do it without messing up the paint on your valve covers. If someone has any bright ideas, fill me in because I would like to remove and replace those to better suit my catch can setup.
slavetothemuzic
Sounds like the whole buying a spare set to avoid downtime isn't going to happen then.
wawazat8402
Car: 89 Sil80- RB25DET
I just got a nice soft rag and some channel lock pliers. Twisting more than pulling. I flipped mine around so that I could mount the catch can on the intake side without a lot of extra tubing.
