rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Fri Feb 10, 2006 11:43 am
Alright I plan on replacing my valve cover gasket, and when I was loosening the bolts the third one I got to was broken off in the head. The head of the bolt went flying into who knows where (it's just gone) and the threaded part of the bolt is still in the head.
My question is...... would it be a problem if I just ignored this little "problem" and replaced the valve cover gasket w/o that bolt??
Would it leak oil if I did that? It's only one bolt on the side drivers side of the cover (across from no 2 spark plug).
Also, I've never done a valve cover gasket before, any thing that I might not be expecting as far as other problems, like the origional gasket sticking to the head, or their being peices missing from new set or anything like that??
