Valve Cover Oil Leak Poll
s13redmon
Car: immobile s13 hatch
Who doesn't have it? How did you get rid of it? I just can't understand how it could leak around a brand new gasket mated to perfectly clean surfaces.... I know its not crankcase pressure because any gases that want to come out can go straight out of the top of the valve covers, right?
P.S. UV die is the shizzle for finding leaks
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
had a friend with so much CC pressure it was coming out the bolt holes on his valve covers.
I dont leak at all..... nock on wood
s13redmon
you're so lucky lol the whole underbody of my car looks like it has rhino lining. but the center section of my turbo is leaking all over the place too... so many problems, so little money lol
float_6969
Mine leaks, but it's from a crack or something in the valve cover itself, not the seal.
s13redmon
mine may have a tiny crack then because it was leaking when i got my swap, i've changed the gasket twice and it still leaks a good bit... i was thinking about getting one of my friends to machine a piece of metal to replace the half moon plugs, something about rubber trying to seal to rubber just doesn't sound very good to me.
float_6969
What gasket are you using? If you use the Nissan gasket, it's 3 pieces per cover. If you use the Felpro gasket, they mold the 1/2 moon piece into the regular gasket, so it's only 1 piece per cover.
Felpro is generally pretty good stuff.
RS12Turbo
float_6969 wrote:If you use the Felpro gasket, they mold the 1/2 moon piece into the regular gasket, so it's only 1 piece per cover.
Really...what part number? The Felpro kit I bought, the half moon pieces are seperate....
Also, how much torque are you putting on the valve cover bolts? I think the fsm says like 10ft lbs or something....not very much I know. I cranked mine down one time, and they leaked. Loosened them, and torqued them down to whatever the fsm says....and no more leaks
s13redmon
The felpro kit i got was two pieces too, where did you get yours float? But i definately over-torqued the bolts so thats probably it.
rico05
Car: 1992 RMS13 w/ CA18DET
No leaks here. I had the same issue with overtorque as I switched to stainless hex bolts over the factory fasteners so it is much easier to over tighten.
s13redmon
yea.... mine are torqued to at least 35 ft-lbs i'll get new gaskets tomorrow and do it right lol
s13redmon
your car looks really clean rico, i'm trying to decide what color to paint mine, really considering blue with black pillars and roof
Fleemer
Car: Pulsar Exa, FC3S
anyone ever bother to replace the half moons when doing the valve covers?
i was too cheap to pay the extra 40$ to get them :P
s13redmon
$40!!!!! we can get them for like 5 bucks here in greer at advance, and they're usually in stock, the gaskets are 16 each and the plugs usually come with them if you get the felpro from advance or autozone....
Fleemer
canada sucks..
i'll try again (its been 2 years), cause that's where mine are leaking from :P
s13redmon
if you can't find them there i could send you some from here
