valve cover not sealed tightly?
marryson
Car: 240sx
my car ran fine before I took the top valve cover and the front cover off to take the timing chain off. after I put everything back, the car would idle for about 10 second then it would die. when I try to give it gas, the RPM would just dip then dies. is it because my valve cover is not sealed tightly? and yes I have adjusted the timing when I put my distributor back in(otherwise the car wont even start.) any help is apppreciated
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Oh it can still start if its a tooth off, trust me. I would download the fsm and fallow the timing procedure again. I've seen this 100 times.
marryson
Car: 240sx
oh really? dammit.... that means I gotta adjust it again. thx man
sly240
Car: 93 240sx
It would help if we knew what engine you have. :gotme
And your car can run without the valve cover on at all. Although it is not advised.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Yes recheck the cam timing then dissy timing, then check for hose and fitting breaks
marryson
Car: 240sx
problem solved... thx for compact. the distributor was off by a TINY BIT.... cant imagine that would cause such a big problem... so yea if that happens to you the next time, you know your dis is off.
