[quote=" tenkawa_akito
the nipple as you call it is where the knock sensor is located if i remember correctly. it should connect to an air hose situated behind the fuel rail.
knock sensor location [/quote]
The knock sensor is on the block below the intake manifold.
J-Spec Tuner wrote:Mine doesnt fit with the new manifold, what does it do exactly anyways?
And, you don't want to remove it because it acts as an oil separator...keeping oil from coming out of your breather. Alot of people eventually saturate their little filter when they take off the stock catch can and oil starts going everywhere. So, like Speed Racer said, keep it if you can.
