xswamperx »
https://forums.nicoclub.com/xswamperx-u168427.html
Thu Aug 02, 2012 12:43 pm
Just did my valve covers last week..man what a job 97(3.3L). Passenger side was easy no prob took a cpl hrs but i cleaned the snot out of the cover and the two mating surfaces meticulously. Driver side was a true nightmare, had to remove the whole intake plenum to access the valve cover. Ohh an the heater hoses on the back of them are no joke to remove/which i ended up cutting w/ a flat razor blade..or to reinstalling them either. Nonetheless I finished the driver side up, spent a day an a half on it..and shes running beautifully. I can only attest that because of how much I truly cleaned every mating surface up..(to what looked brand new), that I had no leaks.
Now I ask you this..Did you clean the covers and mating surfaces really good before installing your new gaskets, making sure there was no oil on them? and did you get new rubber grommets for your top side screws/bolts? Is it leaking from the screws or the gasket part? Did you torque your screws down properly? The top screws on my valve covers had a torque value of 9-26lbs. Don't just tighten them all down at one time either. Follow your sequence order and ease into your torque value. I followed my sequence order for about 5x around and tightened them slowly down until I got to 15lbs roughly. If all this still fails you when go to fire it up again and it leaks..then you most likely, in my own opinion have a jacked up valve cover and you'll need to replace that. If it got a little bent, or when cleaning out the old gasket material, you happened to scrape any portion of the metal mating surface, then its gonna leak.
