You should get a torqe wrench. They are cheap. Fsm for specs.sxcoupe wrote:should you torque them to any spec. if so how many foot ponds or should i just tighten them becouse i dont have a torque wrench. "please" the more info the beter on this one. i am in uncharted water on this issue.
Yeah that is the ticking. That writup explains valve cover removal/installation, as well as how to remove the unnessary chain guides. I suggest that you do it all at once. Follow it step by step, it is a really good writup.sxcoupe wrote:timing chain guide is that the little click click click sound i hear when i am idelling. when im under the hood and reve the engine then let i idele i get that sound is that what that is. thanks for the link it explaned alot.
They are actually made out of metal. Nissan says they are unnessary. They are most likely not broken. The timing chain just kind of slaps agains them and causes the noise. Your timing chain is most likely in fine shape. Timing chain's generally outlast the motor itself.sxcoupe wrote:thanks again so you dont need those guides at all why do that put plastic in a engine were they know metal parts are going to be in contact with it. seems kind of dumb to me. i forgot to ask you the clicking noise, dose that mean its broken of in there or just worn like one on link.
