My recently acquired 2000 AE has 102,000 miles and currently runs and idles smoothly. I have done a bunch of simple maintenance and repairs. The valve cover gaskets are leaking and a local independent shop with a good reputation has quoted me $255 in labor to replace the vcgs. They will let me purchase and supply my own gaskets or they will order a Felpro gasket from their supplier at a cost to me of $50. This seems like a really good deal based on what I have been reading here for this job.
I want to stack as much other work as I can into this job and see what sort of a package price the shop will be able to give me. Again, I can order and supply my own parts. Based on what I am reading here, it sounds like I should definitely ask for spark plug replacement. I have maintenance records for the car and I don't see that spark plugs have ever been replaced. I have a receipt from 2013 which shows that all ignition coils were replaced with parts supplied by the customer. The labor charge was $102. So I don't think I need to do the coil packs. I am looking at these plugs:
http://www.amazon.com/NGK-BKR5EIX-11-Sp ... B00BRSALK8
The shop has quoted $45 extra labor charge for spark plugs, which sounds fair. I am also reading here that I should have the EGR tube cleaned, the throttle body cleaned, and MAF sensor cleaned as part of this overall job.
Are these parts all exposed for cleaning as part of the vcg job?
How much extra labor charge seems reasonable for the other items (clean EGR/TB/MAF)?
Any other work that I should request as a part of this project?
Does a Felpro gasket sound ok for this job or should I get another brand?
Maintenance records for the car indicate that the knock sensors are bad. Prior owner elected to not replace them and her mechanic thought that was no problem.
Are the KS accessible as part of this job? Are they worth replacing?
I see some KS on Amazon for only $7/each.
http://www.amazon.com/Angstrom-Autohaus ... ock+sensor
I am trying to be efficient with my maintenance dollars and think this through before I go back to the shop to make a final deal. Thanks for any help.
