I thought half moons are only for the 90-93 and they use a silicone gasket. The rubber washers are for the 94-96's as well as the rubber gaskets.maxnix wrote:Probably at least 20 different threads also.
Joe is the guy. Get the half moons also. Be aware that teh special metal backed rubber washers are probably hard and deformed. No one seems to replace them, but it is ~$160 for all of them.
Difficult to imagine one achieves correct torque with old, hard and deformed ones.
So no metal backed rubber washers? I stand corrected.96’er wrote:I got the schematic for the '96 Q and the VC gasket is one piece.
Yeah, the reason it's leaking and retorquing may be possible is the gasket has lost its elasticity. Why retorquing is so dangerous and why the gasket must be replaced. With earlier RTV, I wouldn't even think of retorquiing.qsiguy wrote:Tried that myself. Unfortunately I'm beyond that point on my car, didn't help.
If it worked for you I wouldn't even worry about the "getting flamed" issue. I had an issue with my VC gaskets leaking after the switch to M1. I changed out the pax side, but couldn't change out the driver's side because I wasn't informed that I needed the IAC & TB gasket. Well I've purchased those and I'm ready to change it now. Well, I've swithed back to dino Mobil Clean 5000 oil and I don't smell the oil anymore. Yes, I still will change the VC gasket, but I can wait until I have more time now.oldmako wrote:For sure I'll get flamed for this but perhaps one guy will glean some benefit.
When I bought my car in NOV the pax side leaked a bit...not a ton, but enough that you could smell it. It was cold as hell and I was not in the mood to replace the gaskets outside in the lousy weather so I simply resnugged all the bolts. That was in NOV and 3 oil (M1) changes ago.
The leak has stopped. Will it start again....probably. But perhaps it will start leaking (or the gasket will be preemptively replaced) when I am ready to work on it.
How does the engine know which lubricant it contains? The best oil is always fresh oil. It all detiorates from condensation, blowby, heat. Synthetic just has a better performance envelope.NightRiderQ45 wrote:I didn't benifit from M1 because my OCI was still 3-4k miles. Speaking of oil, after visiting the Bob's the oil guy website, everyone there states that Penzoil Platinum is the best synthetic to use with long OCI and they have UOA's to back it up.
That's what I did. 8 new plugs for $104. I explained to Keith about the hose issue and he said that it would be best for him to just do the hoses I have now. He said that if he sees anything that needs to be immediately taken care of under the plenum, he'll just order the part for me. I spent about 5 hours at the shop just talking to Keith in between jobs and customers. It's a great place. I saw a 94-96 champagne Q that has been there since November. It had Delaware plates. Who's is it? Anyone on here?elwesso wrote:personally I just threw the gaskets on dry, no RTV. A little RTV may not hurt, probably a matter of preference...
If you're over half way to a spark plug replacement, throw 8 new plugs in! You wont want to go back in there after you get done with that.
True, true, true. That's why I switched back to dino Mobil Clean 5000 which is a good oil. Since I love changing the oil myself, I can purchase a 5qt. of MC 5000 for $8.97 and my beloved SuperTech oil filter for $2.50 from Wally World. I can change my oil for $13 max every 3500k is great!maxnix wrote:How does the engine know which lubricant it contains? The best oil is always fresh oil. It all detiorates from condensation, blowby, heat
Man, who "butt-raped" you for the cost of those plugs?! That's like $13 a plug. Advance Auto has the OEM plugs here for $9.97 and I've seen as low as $8.97/plug. Did you purchase from the dealer?Haitian_King wrote:
Hmmm...I wasn't aware that those gaskets were required either. I got the valve cover gaskets and the TB gasket coming. I wonder if the IAC gasket is included in the under plenum hose kit. If not, I guess I'll be stopping by my local Infiniti dealer to pick one up. Dammit.NightRiderQ45 wrote:I changed out the pax side, but couldn't change out the driver's side because I wasn't informed that I needed the IAC & TB gasket.
Yeah, I would have thought Joe knew exactly what gaskets I needed. Trust me, you do need it. I was upset because I took a day off from work and STILL didn't get the complete job done.DoinkMobb wrote:
Crap. Well, there are a few things I could pick up at the Infiniti dealer so might as well make a trip out of it. My parts should be coming in on Tuesday and I'm off all next week, so I should have enough time to get everything done and then figure out why the car won't start and then consult NICO and then fix what I screwed up by next Sunday night.NightRiderQ45 wrote:
Holman Infiniti of Maple Shade deflowered me on that one.NightRiderQ45 wrote:
Modified by NightRiderQ45 at 7:06 AM 3/19/2008
When pulling the plenum you will need/want:- plenum gaskets- throttle body gasket- IAC gasket- EGR valve gasket- lower runner gaskets(?)- valve cover gasketsmaxnix wrote:When you pull the plenum, you wiil proabably want the lower runner gaskets also.
