I was a little scared due to other threads on the site advising to take to a mechanic but i still went for it.
It did take me a little over 10 hrs but I took my time with all steps and was successful. The driver side which seems daunting isnt really that hard... once all the air intake stuff is removed, its even more roomier than the passenger side. This is my first true repair adventure and it was something anyone can do.
I did have a couple scares.. once i finished the driver side, i started up to test but unknowingly forgot to plug a vacuum hose which made the car stall. I found the issue and corrected it but forgot to plug a switch/sensor going over the hose which caused the TCS/SLIP lights to come on.. That was also corrected. Worst of all was smelling burnt oil while testing... i thought i had put the gasket in wrong ( it is a pain trying to put the cover back on with the gasket without it falling out of place) however this was just because during the removal process some oil leaked out therefore the burnt smell.
I was able to replace all spark plugs which were pretty bad but unfortunately they shipped me 4 coils that were not for the car so i will have to return those and still take apart the driver side...
Overall like i said it wasnt that hard... if youre thinking of doing it, take your time is the best advice.
Some pics
BTW.. That bracket doesnt need to be removed or cut... just slightly bent upwards
