I've re-used mine a few times. As long as it doesn't look damaged, just re-use it. If one of them is damaged, it's only ~$11 to order a new one.fritts wrote:Question, when taking off the valve cover is a new valve cover gasket mandatory? Does it usually fall apart?
Just put it in. The only thing that needs RTV is the little half-moon pieces that sit in front of the cam sprockets. You just need to put a bead of RTV on the curved side of the half-moon and that's it. The FSM doesn't call for any RTV on the valve cover gaskets themselves.240fan wrote:I am putting Felpro in in a couple hours, do I need to coat it with RTV or just put it in??
