JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Wed Nov 06, 2002 2:20 pm
RTV is a silicone sealer you can pickup at your autoparts store. To scrape it, i would suggest getting a razor blade and going gently over it, being careful not to score the metal (its alluminum, which is soft and easy to mark up). Same goes for tightening the valve cover bolts back down. I would actually get a screwdriver type attachment for your 10mm bolt and put them down tight with that, not with a socket wrench which might overtighten and strip the thread out.
