Valve Cover Gasket Seating
240nspec
Car: 1991 240sx Hatch KaDe
Pulled Valve Cover today, purchased a new Valve Cover gasket, both outer and inner. Prepped all surfaces, Applied a 1/8" Bead of Copper Based Hi-Temp Sealant (Permatex) on the spark plug chamber and bolt holes. Installed the Inner Gasket and let set. My question for you, should/do I apply the gasket maker on the gasket, install within the valve cover itself, re-apply the sealant on the "dry" side of the gasket along the perimeter, apply a bead say 1/4" dia along again the perimeter of the 4 channels of the head? Do i also add sealant to where the inner gasket seats against the spark plug chambers and valve cover studs?
Iv'e included a few drawing i whipped up, apologize for the crudeness as I only have paint.
Modified by 240nspec at 6:24 PM 6/7/2008
240nspec
I read the write up on replacing the timing chain and included was the instructions for the headgasket, however it just seems this is very minimal as in liquid gasket concerns. I have always seen gaskets being sprayed top to bottom with a copper spray gasket, or a bead of rtv on all contact surfaces including bolt holes... even the concept of bare cleaned metal to a dry gasket seems like a poor seal. Not even a thin thin coat of oil where gasket comes into contact of head?
any ideas?
Moto Man
Car: 93 240SX
I don't know, but I need to as I have to fix my upper timing chain guide.
I couldn't find any mention at all of a valve cover gasket in the factory service manual.
How much did the gaskets cost you?
240nspec
About 20 for the Main gasket, or for the set (The main and inner gasket) for about 30. I purchased Copper Hi-Temp Gasket maker at Autozone, and the gaskets at Advance Auto Parts.
hope that helps.
240nspec
can anyone help? I shall be installing this gasket within minutes, as i must leave.
Vegascorbin
Car: 1990 240sx dirt track race car
I know you probably have finished the job but this may help others or you in the future.
Remember that the pourpose of a gasket is to provide a seal where two pieces of metal meet. The RTV is the same as a formed gasket. One big advantage is that the RTV will fill areas too small for a "regular" gasket.
Putting RTV on a "regular" gasket is the same as putting two gaskets on. Generaly you want to use one or the other. Auto manufacturers use RTV or liquid gaskets, so that they only have to stock the RTV and not 2700 different gaskets.
You will find people that will only usr RTV and others that will only use "regular" gaskets. There are Pros and Cons both ways.
Most "regular" gaskets come with instructins on NOT useing RTV with them. Some will say what and how. Follow the recomendations, if any, that came with your gasket set. Otherwise just use one or the other but i would avoid both at the same time.
vancouverbc
Car: 1991 240sx
Vegascorbin wrote:I know you probably have finished the job but this may help others or you in the future.
fsm says to use both in specified area due to shape of gasket.
Moto Man
Car: 93 240SX
I bought new gaskets ($27/each ). They're not like the regular thin gaskets, they are thick rubber.
As you can see, mine has the end plugs built-in.
Modified by Moto Man at 6:44 PM 6/9/2008
Moto Man
Car: 93 240SX
Well, I took my valve cover off to fix the upper timing chain guide but it appears to not be the source of the noise.
The chain guide looked just fine so I left it alone. Everything else looked really good too. So IDK.
I did replace the gaskets though. The old ones were much less pliable than the new.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
When i first got my s13 the valve cover gasket had oil leaking out around it so i replaced it.With the new felpro i initially had used silicon sealant, but i took the valve cover off a month later to swap out cams. Pealed the silicon off in the process and just stuffed the gasket back in and tightened it down. No leaks a year later.So as long as your replacing with a nice soft new gasket, you shouldn't need sealant for the outer but i would recommend using a little silicon around the spark plug tubes.
Vegascorbin
True. That is the exception that proves the rule.
BMAR240SX
Car: 1993 Nissan 240S Coupe
So umm any exact place or order to apply the sealant i want to do this today
vancouverbc
Car: 1991 240sx
BMAR240SX wrote:So umm any exact place or order to apply the sealant i want to do this today
if in doubt, use sealant. seal gasket around stripped bolts. hand tighten bolts plus a little bit more. most people strip these bolts. 5 to 8 lbs torque.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I just put a valvecover on about a week ago and I only put gasket on the four halfmoon sections and the spark plug wells under the valvecover. Hijacker later told me that putting gasket on the spark plug wells is over-kill as the rubber gaskets seal just fine by themselves. That guy knows his stuff.
BMAR240SX
positron_ wrote:I just put a valvecover on about a week ago and I only put gasket on the four halfmoon sections and the spark plug wells under the valvecover. Hijacker later told me that putting gasket on the spark plug wells is over-kill as the rubber gaskets seal just fine by themselves. That guy knows his stuff.
When you say gasket you do mean, sealant correct?
positron1
Yeah, my bad. I put the rubber gasket on and the sealant on the halfmoons and spark plug wells with the rubber spark plug gaskets.
BMAR240SX
Ok i will do it tommorw
I will add sealant to the halfmoons and the spark plug gasket
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
yep half moons and your good and also anywhere stripped bolts may be, but be careful because they are easy to strip
