sanioll »
https://forums.nicoclub.com/sanioll-u18155.html
Fri Apr 01, 2005 2:12 pm
*Note: I have unadequate knowledge about engines. FYI.
Today i changed my valve cover gasket beucase it was leaking just a bit due to mobil 1 full synthetic.
When i put the screws back on, obviously i used a torque wrench. Used less then 10 ft/lbs.
3rd bolt, and every other side bolts like 3, 6, 5, 2, also #1 is kinda loose. They are not as tight as the corner bolts 7, 8, 9, 10.
i was turning the 3rd bolt and i was like WTF, why the torque wrench not clicking. I even set it to less then 10 ft pounds.
i took, 3rd one out and this is what i found. see pics below. middle one #1 bolt was also feeling loose so i didn't tighten it anymore.
Well, see the pics.
Modified by sanioll at 7:30 PM 4/1/2005
