NutriaforBreakfast wrote:I am planning on replacing the valve cover gaskets and spark plug "gaskets" onmy 95 Nissan Maxima. Plan on using OEM.
Does anybody have another suggestion, maybe a better gasketthan stock?
Also, I am going to replace the hoses under the pleneum, heaterhoses, and maybe some other electronic components. Maybe thefuel injectors.
Any recommendations on replacing items?
What about that wiring harness going over the plenum? Is that hardto move around after the injectors are disconnected? Can tell where thatthing ends and begins.
Stock gaskets are the best bet for this job.
You will have to remove the upper intake to do this.
It is a good idea to change the injectors under the intake since you are there.
Be careful with the wiring harness because this car is know for wire shorts that cause stalling and no starts.
The heater hoses should be fine. The smaller coolant hoses may need to be replaced.
Good luck
