Valve cover gasket leakage
RS12Turbo
Just curious if it's ok to use RTV with the valve cover gaskets? Seems like on the FelPro box the gaskets came in, it said not to use sealant.....I discovered an oil leak, and I'm pretty sure it's coming from the half circle gasket piece that goes on the back of the head on the exhaust side valve cover.
dvd
I used high temp rtv on my valve cover gaskets and they still leak =\ . I made a post similar to this awhile back and i think other people had the same problems.
RS12Turbo
Any resolution?
themadscientist
CA and RB valve cover gaskets leak pretty much from day #2. Try anything you can think of.
biosehnsucht
Mine don't leak, don't overtighten them, and install them like you'd install cams or wheels.. I used RTV like on the half moon thingies but not on the big goes-all-around part, I don't think. Either way mine don't leak..
float_6969
Mine don't leak either. Felpro FTW.
themadscientist
I just top off from time to time and enjoy my oil-coated block and transmission.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
less chance of precious metals rusting when covered in oil!
themadscientist
True and my car marks it's parking spot like a dog pees on a tree.
Hillkill
Car: s12(killed), s13 hatch(rebuilding CA), s13 coupe(low & slow), e30 4door, FJZ80, ThunderChicken
If its leaking from that half circle, you should put a dab of rtv in the corner where it meets the head. Worked on mine like a charm
rico05
Car: 1992 RMS13 w/ CA18DET
Mine leaks like CRAZY from between the upper and lower halves of the exhaust side. Freaked me out that I thought my head was leaking.
Crustal200sx
Car: Ca18det nissan 200sx
float_6969 wrote:Mine don't leak either. Felpro FTW.
Which felpro do you use?
Izento
Car: RPS13
OEM isn't that expensive guys.
float_6969
Crustal200sx wrote:Which felpro do you use?
Is there more than one? I walk into Advance Auto and ask for a valve cover gasket for a 1989 Nissan Pulsar SE, 1.8L. They used to stock it. They're old enough now that the last time I needed one they had to order it, but it was there later that same day.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
https://www.ebay.com/p/?iid=26203620024 ... rue&chn=ps
^^Buy these and torque to spec. If you are using the OEM screw style fasteners you probably don't have them torqued down to spec and the gasket won't seal properly. For me, using these bolts and torquing them down per the FSM fixed my leaky valve cover issue.
You can see pictures on page 9 of my thread here to see what I mean --->sjbsuperman1425-s-upgrade-thread-t399444-240.html
Izento
Car: RPS13
sjbsuperman1425 wrote:https://www.ebay.com/p/?iid=26203620024 ... rue&chn=ps
Those bolts look pretty nice. Think I might order some. I try to get away from Philips screws as much as possible. They always seem to strip if the screw driver isn't in brand new shape.
