Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Mon Feb 09, 2004 9:14 am
I did my '94 Q passenger side VC gasket in about 2 hours, including cleaning everything. I had already replaced the plugs, but wish I had done them together.
I have not done the driver's side, yet, since it started getting colder. I will do it soon.
It is a DIY job, but you must be careful, and not try to rush. Take pictures, if you think you might forget where everyting goes. Be careful around the fuel lines. I stressed a hose under the plenum, and now it seeps gas, when the temp drops below freezing. Probably would have done that, anyway.
Once the VC is off, the plugs are right there.
I think another 2 hours for the driver's side. Not quite as easy as a Small Block Chevy.
