valve cover gasket change
jester4666
Car: 1994 Infiniti J30t
ok, i've done a search and didn't get the info i'm looking for. i know it's not straight forward like on any of the other vehicles i've owned, so i'm looking at what all i have to get/do to take care of leaky valve cover gaskets. since the plenum has to be removed, i'm guessing that there are other "gaskets" that will need to be replaced as well. all info is welcome. since i've decided to keep the car, i want to get rid of my oil leak.
yodawill2000
Car: 94 Infiniti J30
I'm in the same boat(leaky Cover)
You will need to replace all the vacuum lines I'm sure.
Someone who has pulled the plenum should chime in soon.
yodawill2000
Also ,
here is a pretty good how too from the z32 forums.
http://www.thedevilsz.com/site/technica ... m_pull.pdf
jester4666
thanks. i don't check the z forums since i'm not sure of the similarities and differences in the motors.
yodawill2000
The 300ZX N/A engine is the same as ours.
jester4666
looks like just the valve cover gaskets and a plenum gasket to change. i like the list of other things you can get at after taking off the plenum as well.
yodawill2000
Vacuum and Fuel lines are cheap and easy , And I plan on doing the Throttle body water hose deletion as well.
We don't need that down here.
jester4666
it's gonna be an all day thing, i can sense it now.
yodawill2000
It will be an all Weekend thing for me !
:gapteeth:
jester4666
well, yeah. if the weather holds out, i might do mine next month.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
you will need new fuel line and a new plenum gasket. you may want to get the silicone pcv and iacv hoses from z1 and replace them as well. makes putting it back together easier and a pretty good chance one of those old hoses may split. hardest part is getting the egr tubes out of the plenum. and like yoda said, delete the throttle body coolant lines while you have the plenum off and re-route the lines off the heater core hard lines.
http://s95014253.onlinehome.us/63104/16304.html
here are some photos when i did valve covers and motor torn down
