mprice wrote:Are the spark plug seals and grommets the same thing?
What does "IMO" stand for?
When I take the valve cover off will I see all of the spark plug seals?And won't I need a new valve cover gasket once I take off the valve cover. I'm thinking the valve cover gasket will break once I take off the VC.Are the gaskets just rubber, or are they glued in with some kind of silicon?
The only seals you need to worry about are the ones built into the actual valve cover. They probably just slipped up over the actual spark plug chamber causing it to leak.
IMO stands for "in my opinion"
If you unbolt the VC, you will see the small circular rubber seals that go around the spark plug chambers (3 on each bank). You can also see them by looking at your spark plugs with the coils removed as they go around that metal chamber the spark plugs are housed in.
The gasket is just a strip of very durable rubber, and like I said, mine felt exactly like the new one I bought, so I really don't think there's any need to replace it upon removing the valve cover.
Just remove the coils and look at the metal "tube" that the spark plugs are in (the chamber I've been talking about) and look to see if those rubber seals on the outside slipped up over the top. If so, all you need to do is remove the VC real quick and re-install it making sure to adjust those rubber seals further down the chamber so that they don't slip again.
But like I said before, it seems that the new maxima's valve covers have a bit more of a rubbery (ie: sticky) material making up the seals which, I think, will help prevent the same thing from happening in the future. It's not a bad buy at $30 and you get a PCV valve and everything. Good luck, and let us know what you find!
