Valve cover bolt thread size? VQ35DE
A forum for the Nissan Quest... minivan lovers unite!
schuylkill
Car: 2004 Nissan Quest SE
So my latest hot off the press screw up, I am reinstalling the valve covers and I snugged up the bolts and then set my torque wrench at 17 inch pounds and proceeded to snap off the head of the first bolt I tightened. It must have been tighter than the setting on the wrench I'm guessing and wrench never clicked and I messed up again. Live and learn. At 68 years old I probably learned and forgot that one, discouraging. Anyway does anyone have the thread specs for those bolts? At least it's an accessible location. I never have luck with extractors, thinking I'll just drill minor diameter hole and rethread it carefully. And any suggestions on where to get a bolt, no dealerships nearby. I saw one for $.067 at a dealership but $10 shipping. Wondering if I can do better. So I need thread size for rocker cover bolts and a bolt. Thanks!
schuylkill
Looks like it's M6 x 1.00 with a 5 mm drill hole for threading. I'm still looking into whether I should try to remove the broken bolt or just drill and tap and hope I don't cross thread the head.
Any experts on this job?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If they came out clean the first time then there's no reason to think they'll be buggered just because they broke. I'd try an easy-out.
schuylkill
Yeah thanks that's what I decided to try first. Bought this too to get the hole as centered as I can. https://www.amazon.com/gp/product/B0000 ... UTF8&psc=1 It's really frustrating, all I had to do was tighten the bolts and I was finished. Using the manual for sequence and torque. Oh well I just hope all is good once I get finished with all of this. If not that would be depressing.
VStar650CL
Technical Expert
With valve covers, consistent torque matters much more than absolute torque. I usually use the finger method, one finger with a short 1/4" ratchet. Check with an in-lb wrench and you'll find they all come out very close.
schuylkill
Hmmmmmmm. I need a right angle drill or such to get to the broken bolt, it's accessible without breaking my back but not enough clearance for my drill motor. I will look into your method. I didn't get an OEM valve cover but what I have seemed to fit ok. It's annoying that the spark plug tube seals are built into the cover.
VStar650CL
Technical Expert
I use one of these, Harbor Freight, $20:
https://www.harborfreight.com/power-too ... 69337.html
Or you can get a flex extension like this, Amazon, $24. I used to own a similar one but I'm not sure what became of it:
https://www.amazon.com/Eyech-0-3-6-5mm- ... NH58&psc=1
schuylkill
This is arriving tomorrow, thinking I might do some practice holes first. Hopefully it works
https://www.amazon.com/gp/product/B07VY ... UTF8&psc=1
VStar650CL
Technical Expert
schuylkill wrote:
Sat May 15, 2021 5:30 pm
That should work fine, it's just hex drive instead of drill shank. You'll need hex-shank drill bits, but other than that it's better because you can use it with either tool, drill or driver. You're right to practice first, they can be awkward. Using a tool with a trigger-lock will make things easier as well.
schuylkill
I have this. Going to use a left handed drill bit in it.
schuylkill
schuylkill
Got it out no problem, imagine that.
VStar650CL
Technical Expert
schuylkill wrote:
Sun May 16, 2021 2:30 pm
:dblthumb:
Return to “Quest Forum”
