Valve cover bolt size
GoofyATX240
Just needing to know the length and size of the bolts that hold down the valve covers. Anyone know? Yes I did a search and came across some info, but wasnt exact on the size.
NeedCAforS13
Car: CA swapped S13 coupe
korey, find the proper pitch of the bolts and put studs on there... that way you can get them a little bit too long, and hold them on with nuts rather than bolts
Sean
GoofyATX240
Sweet I didn't think of that. Thanks man ill probably go out today, and get the studs when I pick up my wideband.
Jezz_s13
Car: Sil80 Track Car
You mean the cam covers?
they are m6 std pitch.
there are also two different lengths IIRC, can't remember what they were though. something like 40 and 60mm but not 100% sure.
