OK well I didn't want to continue driving the car the way it was so I had it towed to a shop. To address some of those points... It def was coming from the top end, and the noise was def valves ticking due to low oil pressure. Just not sure as to why the oil pressure was or is so low and what causes the oil pressure to go so low...RustspecS13 wrote:First Fill your oil completely up
Second make sure the oil light isnt on. If it is, your likely screwed. That light comes on when pressure is below 12psi or so. An engine can not run with 12psi, normally its 30-80psi.
Third find where the noise is coming from. If it sounds like it has multiple sources from the top of the head, you might be ok. If it sounds like one loud/deep source in the bottom of the block, you need a new engine.
Fourth look on you tube for similar noises, search for "valve tick" or "rod knock" and similar things.
If it is rod knock, you don't have many miles left on your motor. My sohc KA started making faint noises on my last two laps at the track last week, and I stopped right away. It only knocked 3500+ rpms at first. I tried to drive it home, and I made it 9.5 miles before it sounded like the rod wanted to exit the block at any time. I don't care because I have an RB to replace it.
You can pick up a KA very cheap though, any where from free to $250 is pretty typical.
Good luck ~Alex
So its just likely that the tensioner has become stuck? I mean do they malfunction too often? Or is it just that its all gummed up in there?numbnuts240 wrote:remove valve cover, remove upper timing cover, douse tensioner in wd-40, push it in and out until it moves freely, put s*** back together. 2 hours, tops.
Usually just the upper guide that gets stuck? Because don't you need to take of the dizzy in order to get to the lower guide?numbnuts240 wrote:probably just gummed up. mine was a little bit gummed up, so when i removed the guides, i freed it up with wd-40 and it's been doing just fine since.
Do you even bother to read posts? I already stated that the shop told me that it was the timing chain tensioner...OutToWinPAHC wrote:Oil light on..... key off tow it home.... dont drive it man.
Check oil, check actual pressure (real gauge) and then use a wooden dowel to source the noise, it could just be lifter noise, but if you got the light and lost pressure I would think bearing.
numbnuts240 wrote:not the guide, tensioner. you need to remove the upper timing chain cover to get to it, which means you have to pull the dizzy. it's not hard at all. follow the write up for removing the guides (might as well do that while you're in there). it makes note of "conditioning" the tensioner.
If you are that far in why would you not replace the chain if you don't know the history? Would the tensioner cause that much of a drop in oil pressure? That doesnt' sound right to me but I haven't researched either.NICONick wrote:Do you even bother to read posts? I already stated that the shop told me that it was the timing chain tensioner...OutToWinPAHC wrote:Oil light on..... key off tow it home.... dont drive it man.
Is it true what the shop told me? That you have to take apart the whole top end in order to replace the timing chain tensioners? Also, that you have to buy they in a kit and can only buy them in a kit with the timing chain, tensioners, gears, etc.? Thats just what the shop told me.....
Very tru... Well the shop said that the hydraulic tensioner went and thats what was causing no oil to get up there. I dont kno if there is any difference in the upper n lower tensioners and the hydraulic tensioner... needless to say I had it towed to a reputable source (one i kno is not going to try to d!ck me over) they are going to just replace the motor, said he would charge me less in labor to do the swap. So, Im having an 86k KA put in...fiznowler wrote:
