Valve Chatter (or maybe paranoia)
TRBOMOFO
Car: S13.5 built redtop
I did a search and cant find exactly what i am looking for.
I am running 14 psi on my stock T25
got FMIC and 255 Walbro Fuel Pump
i have done 2 over revves (sp?) by popping the clutch and spinning the tires
and now i think my valves are chattering (maybe i hear this noise) is that NORMAL? or am i really hearing my f*ck up
are they soild lifters or hydraulic lifters
i dont run this car all the time this is like my show/ mess around car so i will have it out at a month at a time then it is up for 3
TRBOMOFO
i will answer my own question
i called my nissan spec down at VA that works on these motors
They are hydraulic and the over revving thefew times i did will not hurt anything
the noise i am hearing is the chain hitting a t fitting inside
so it was only paranioa so i am good
time to go d!ck off again with the car
