Valve body
superuber
Whee can I get a transgo valve body for a 08 Sedan AWD?
audtatious
conceptzperformance.com ?
superuber
I found this here...
http://www.forgedperformance.com/store/ ... 562&page=1
Do you know of anyone running a wet nos system on their AWD sedan?
superuber
Better price here:
http://www.summitracing.com/parts/trg-re5ro5a-hd2
I guess today's Infiniti drivers are just that, drivers. No one works on their own stuff much I guess.
douglak280z
Superuber,
Sorry for jumping in your valve body post. I cannot find an alternate way to contact you.
I some very old posts you mentioned that you moved a 4.08 Z32 ring and pinion into a early model Q45 diff. Will you please contact me at [email protected].
I'm wondering if you can recall if you used bushings around the 12mm ring bolts and did you set the pinion depth using the same 300zx pinion bearing and spacers. I know it has been awhile, but would appreciate as much info as possible before I get started. Thank you
