VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Jul 30, 2022 3:01 pm
Fuel pumps do go in-and-out sometimes, but not usually the way you're describing. Intermittent no-starts are the common system for that, from the fuel pump spinning up slowly or not at all. Dying or stumbling intermittently when you hit the gas has five common causes:
1) Bad brake switch - The TCM monitors the brake lamp circuit and won't let the car accelerate if the lamps are lit. If your stumbles are occurring when coming off stoplights, a sticky switch is a likely culprit.
2) Dirty throttle body - Easy to clean with intake cleaner and a toothbrush, but don't force the throttle plate open by hand. Turn the key on and brick the gas pedal so the ECM holds the plate open for you. Pay most attention to the bottom edge and bottom-back section of the plate, that's where crud builds up.
3) Bad, dirty, or miscalbrated MAF - They rarely go bad, suspect that last. They get dirty or out-of-calibration all the time. Easy to take loose and clean, two phillips screws. Use intake cleaner or MAF cleaner, you don't want to leave any residue. After cleaning both the MAF and Throttle Body, do an IAVL (Idle Air Volume Learn). CVTz50 has that capability if you enable "Experimental Features" in the main settings. Great feature, I use it all the time because it's way faster than Consult3+. IAVL recalibrates the relationship between the MAF and throttle plate in the ECM's memory.
4) Crummy PCV Valve - Very overlooked, but sticky PCV's cause all kinds of weird issues because they affect the intake stream and manifold vacuum. Not worth cleaning, just replace it.
5) Crank and Cam Sensors - If you can't find any other cause, CKP's and CMP's are often the culprit. They can get weak but not fail completely, and because reluctance (magnetic flux) of the tone wheels increases with engine speed, they often malfunction only at low speeds and cause no codes.
In this case, since you just changed VB's, I'd give it a few miles to see if the VB also fixed the stumble. It's entirely possible for an unresponsive valve in the transmission to stall the car or cause major stumbles.
