valve body help 2005 Frontier
jgills1992
Car: 2005 Frontier
So here we go guys. I replaced my valve body direct clutch solenoid and high and low solenoid on my 2005 Frontier and nowwwwww I'm having some issues that were not happening before.
1) My truck will not come out of park.
2) There is no link according to my OBD scanner.
3) My truck will not turn over, power is on but nothing happens.
I saw a post where a guy had the same stuck in park issue, but he never replied to what the fix was, which sucks because he had the same symptoms as mine after the repair. Any help is appreciated. I didn't know where to post so I did it here. BTW, I also got the solenoids from a junkyard with another complete valve body.
Reason: Moved to correct Forum
jgills1992
Car: 2005 Frontier
anyone out there ????!!! Hello!!!!!! lol
Q451990
I would look toward a shift interlock issue. It sounds like the car "thinks" it's not in park.
jgills1992
Car: 2005 Frontier
ok guys problem fixed . forgot to connect the small connector to the tcm as i was putting it back in . also i had an allignment issue with my shift valve thing . also dont over tighten ur oil pan or ull have to use a small socket or peice of wood to beat ur pan back straight . remember . start all bolts on ur valve body thennnnnnn tighten down ur allignment bolt . also make sure it shifts smooth from park to drive and so fourth before u put the pan on .
Q451990
I'm glad you got it figured out! Have you bypassed the radiator with an external cooler yet? I'm pretty sure yours is in the "strawberry milkshake of death" run of Frontiers.
jgills1992
Car: 2005 Frontier
i havnt yet . i beleive mine was all replaced under waranty before i purchased it . i have a cooler . i need to look up how to install it . mine is sitting at 260k miles . shes getting old lol
