My key to open the car did not function a couple of days ago, so I used the mechanical key and drove home. In the morning my fob opened the car but could not turn the engine on so I used the mechanical metal key and it turned the engine but it would not start. I suspected the battery which was less than two years old, so I have exchanged it for a new battery. And when it did not start the car I changed the battery in the key fob and again no result. So I called the road assistance and the guy tried to jump the battery but it did not start and he mentioned that there is no gas going in the engine as if the pump has been disabled due to programing issue; as if the car would have acted in case someone was trying to break
into it.
I called the dealer who wanted me to have the car towed to their facility, obviously. And if they just program the key it will be $150 and if it needs a new key the cost is extra $650. So I tried to find other companies specialized in programming and one company said that I should replace the key and program it for $600.
Before I make any decisions I appreciate it if anyone has a better and cheaper solution. Luckily I am retired and I don't have to drive to work which makes it easier to wait a little bit.
Thank you for any suggestions.
Maurice
