Vacuum tank chatter
cjkjday
Car: 1996 Nissan 4x4 Standard Pick-up
I've got a 96 Hardbody 4-cylinder 4x4 and get a clicking chatter from the vacuum tank when turning on the ignition and when turning off. No issues for start-up and running... but annoying. Any adjustments I can make? Thought about replacing the tank...but not sure if it will fix it!? Any recommendations? Thanks.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
My '96 used to do that too. I don't think mine was the vacuum tank though, I think it was a relay. Perhaps the fuel pump relay? Happened every time I'd cycle the key to start or shut it off. I never chased the noise because it was my winter beater so I was happy just as long as it started, it could make as many noises as it wanted.
cjkjday
Yeah... doesn't bother me either, at least not directly (my daughter's truck)! Until she asks me to fix it.
Fuel pump relay makes sense based on symptoms. I'll check that out. Thanks!
