sjbsuperman1425 wrote:the gauge corresponds with my HKS boost controller reading..so i'm guessing its pretty good. I got it to idle better now, still not the same. I did a compression test and got 90psi across the board, but this was with a "loan a tool" tester from Autozone for $40. also did a leakdown test which turned out very good and the car still has tons of power when boosting.
What i did find out is that I am running a bit lean and am burning quite a bit of oil, most likely from a blown turbo..It comes and goes so i'll keep an eye on this.
Would a vacuum leak cause a lean condition?
I'm sure we've all seen this before but for a few of those that haven't, here's what affects idle on the stock setup.
Those compression numbers seem awfully low, try a different gauge.
Vacuum leaks in a Mass Airflow electronic fuel injection system will have a greater affect on overall driveability versus a speed density system (lucky me, i still have my stock setup). A vacuum leak will cause a lean condition. A vacuum leak can also cause the Idle Air Control Valve to close, resulting in a idle drop or idle hunt. If the IACV is malfunctioning, idle quality will suffer.
My idle does a similar thing on cold starts though. The very first time i start the engine, idle goes to 700-800rpm, it drops and suffers to fast idle, then finally it just shuts off. I then start it a second time and fast idle works perfectly, slowly the rpms drop to normal idle and everything works fine. Occasionally, at a stop light, stop sign, or going through a corner with the brakes applied, idle will drop so low and hunt, causing the engine to shut off while going through the corner (very annoying) or while I'm waiting for the light to turn green. I haven't tried replacing my IACV but i did clean and resistance tested it when i rebuilt the engine (i wish i could test it dynamically). I want to buy a new one to test this theory, otherwise I'm suspecting my idle problem could be vacuum related as well.
